Richard.
 - Cambridgeshire
Ok. So confusion has now set in.
My lathe behind the cover has all the combinations detailed for putting the gears in place for both metric and imperial threads. I also have all the gears available for all the combinations. Am I right in thinking it will only cut one or the other or can I cut both by simply setting the change wheels right. If I wanted to swap from metric to imperial or viva verca do I need to make drastic changes like lead screw. I thought it was only done on feed speed but it sounds like there may be more to it. I haven't yet checked whether my screw is metric or imperial. The dials are all metric so I assume it's a metric lathe. Sorry for all the questions guys but I'm trying to get my head around it all and I guess I thought the screw cutting was a simple case of if you had the gears it would cut it.
