I would like to say it is down to amazing skills but doubt I would be believedHow the hell did you find that !!!!
Type tar melting burner into google images and all will be revealed
Looks like the burner we had in the back of the van when I was on BT, used officially for drying cable joints, heating soldering irons etc. Unofficially, making tea, heating soup etc. They are a propane stove.
One of the newer ones with the piezo igniter by the look of it.
When I used one at work, it was connected with standard propane hose with a standard regulator. I wouldn't mind betting that stove was one purloined from BT. I don't know how as all gas equipment had to be accounted for & perodically tested.Standard LH fuel thread for propane I think Parm.
Edit: should be 3/8" LH BSP. Given how hungry it is 8mm bore should be enough but SWK will be able to advise better.
It does have some engraved numbers on the side, so quite possibly so. It was buried under a pile of junk that this bloke had. He couldn't tell me anything about the stoveWhen I used one at work, it was connected with standard propane hose with a standard regulator. I wouldn't mind betting that stove was one purloined from BT. I don't know how as all gas equipment had to be accounted for & perodically tested.
