The_Yellow_Ardvark
https://www.death-clock.org/
- Going Away.
Do you think this can be reused if packed with grease?
Just joking.
This is the best bearing out of 8 on a Hay wagon I am helping my friend restore.
Oddly it was the hub what was the one running with out any noise or wobble.
Yes that is how it fell out of the hub, I have not even wiped it down.
), how critical is it that a motor with roller bearings rotates in the correct direction i.e. the direction indicated by the arrows on the casing? I think it is important but colleagues disagree. WE have to swap on of two vibrating conveyor motors this week and after a direction-of-rotation check on the new one and a swap of two cables we had it going in the direction of the arrow, only to find the conveyor wouldn't (convey I mean) as the vibrations were cancelling each other out. I checked the already fitted one to find it was rotating the wrong way, meaning both original motors must have been, but the maintenance guys swapped the cables on the new one declaring "that's how it was fitted so there must be a reason". I think they should rotate the 'right' way so that if we get another failure we can claim on the warranty without being quizzed on it, what say you all?
