oceanobsession
Can anyone tell me if its possible to us a wp9 type torch with my set. i would like to put the swich on the floor leaving just the slim body and short cap to hand as most of my tig welding will be uptp 100 amps ive seen a weldcraft tig
torch without gas control which has a female thread in the end does the cooper cable fit into the female thread or the gas pipe or is it gas pipe in the centre and copper around the outside or do they both run seperatly the covered only you seem to be able to get a very slim line to the welder containing both maybe 15mm ive got a 200 amp torch at the moment which is switched at the torch handle its quit bulky and heavy and the trunking must be 30mm as ive said i would put the switch on the floor to start the hf
leaving the torch handle for more control ive put a pic of the type im after
