Hi. First try at MIG welding today and I could do with some advice please. Using an Oxford 240, Argoshield Light, with a Binzel torch. First few goes on 1mm steel went surprisingly well, but then thought I'd try 3mm angle. I'll admit to getting the coarse and fine power adjustment knobs mixed up with the result I managed to get such blobby welds that I blocked the tip of the gun. Unscrewing the tip was difficult, I guess because the wire was welded to the nozzle, and the second time was so difficult I then couldn't insert the new nozzle as the adaptor thread was damaged. So, no more welding until an order of new adaptors arrive.
How do I prevent this happening again (or am I just being clumsy?). Should I file the tip down to release the wire before removing the tip? I hope as I improve, and now I know which knob is which, it won't be such an issue!
Many thanks in advance.
Makes it easier to give you some tips about your setup etc.
