Would it look better with a slightly longer gap between twist ? say 3 or 4 inches.Arther
Ok, that makes sence, and yes I do like it ,must take quite a knack to get it in line with the original square of the bar time after time when repeated. ArtherThat wasn't the plan it's the reverse that creates the very effect I was after.
Three twists are not uncommon and two twist very common both are generally done cold you see
To reverse a twist you heat and quench in steps
Take a heat, about cherry red or thereabouts, decent weight hide mallet and a wooden block or stump, usually brings it into alignment without damaging an edge.Ok, that makes sence, and yes I do like it ,must take quite a knack to get it in line with the original square of the bar time after time when repeated. Arther
Nice. It's called a water twist incidentally, because it looks like ripples coming out from the centre. I do it by heating and twisting each side in turn, watching to see that I keep the second twist balanced to the first and don't end up with an odd number of twists on one side. :-)
Thats a view of a twist ive never noticed before and brings me to the question of what determins the spacing between the spiral edges...is the number of twists a direct relation to the spacing or could you have 6 spiral edges with say a spacing of 50mm between and hows this done??
The "tap" wrench sounds to me a accurate way of getting it spot on, finish wise I do like unpainted galvanised especially after the newness wears off, satin black, and the old dark green is good in the country side, all dependant on end location
really.Arther
really.Arther
