WorkshopChris
- South East Essex
Did they shear while you were disassembling or let go as part of the original failure. Removal methods depend on the cause of failure.
ohh yes and try getting that casting on your reversible pillar drill and line it up and hold for drillingWould be quicker to just flip the reverse switch.
Oh, yes, I forgot - pillar drills don't reverse because there's never a need to, can't think why I rewired mine so I could reverse it...
thats why mine dont reverseEasy job with a bit of thought - floorstanding drill with a rotating and tilting table, if that's not enough put the casting on an engine stand and clamp that to the table, swung to the side and rotated to an appropriate position.
I couldn't be bothered. no ofence but theres easier waysSpark erosion is 'easy'![]()
You seem to have misunderstood the 'relative' part...
If you're fully set up for spark erosion then it's a damn sight easier using that to remove a broken stud than using a different process that you don't have the tools for.
Or do you disagree?
and You want a set of left handed drill bits. I had a snapped head bolt in a Volvo T5 engine, used a left handed drill bit and it wound itself out whilst in the process of drilling it.
