CompoSimmonite
What do people recommend for protecting new (ie Chinese or Indian
) scaffolding concreted into the ground ?
Obviously the part enclosed in the concrete should be OK as no worse than rebar. I was thinking of maybe a length of tube over the pole as a former and then pouring a sloppy mix of fine concrete for the aspect that will be below the surface. Above ground galv primer then exterior gloss.
Is it worth painting the part that would be enclosed in concrete ?
) scaffolding concreted into the ground ?Obviously the part enclosed in the concrete should be OK as no worse than rebar. I was thinking of maybe a length of tube over the pole as a former and then pouring a sloppy mix of fine concrete for the aspect that will be below the surface. Above ground galv primer then exterior gloss.
they are "scaffolding tubes" fellas.
