Looks good but try it again butt welding two pieces together. It can be a bit harder as you can blow the edge away if the fit up is not good. Best to know what you are in for before starting on the car.
Only 60, must be a quite new car
Welds look ok, maybe a bit black but that could be the camera/angle.
Does not look like you have blown through at all. What thickness is that sheet ?
you could try a local car body repair place to see if they have a duff wing that you can then find an area which has some rust on the rear and cut out a section, make a new piece and clean up panel. Weld in the new to see how you cope on some less than perfect metal. Try with the panels at some odd angle (vertical welding maybe)
And get away from the disposables![]()
Cheers Mike.Don't forget there is always the copper backing method when butt welding
Thanks. According to T0rnado69 the BOC deal for hobby welders isCheapest deal for the home welder with quite a bit to weld is usually the Boc Argoshield lite deal, known as the 'Volkszone' deal because it was originally a deal offered via the VW mag. There is a big threading it in the Gas forum. As far as I know this deal is still going, though you need to contact head office of Boc to get it set up.
We are on our third Y size bottle on our car resto - it is amazing how quickly you get through gas. The disposables are not worth bothering with imo as you get very little done before it runs out.
I bought a piece of 5mm thick copper on eBay for about £4 which has been very helpful as a heat sink. You can also quench the weld with a damp rag.
The BOC Y size bottle is 20l and filled to a bit more than the *removed for legal reasons* 10l one - so, you get just over double the gas for a little (15%?) less money.
Rental works out approx a quid a week.
But the *removed for legal reasons* one is rental free ,it says...or is there any hidden cost?
Shipping charges for delivering and returning the cylinders possibly. I had a quick look on their site but the link to delivery charges returned a 404 error. I'd guess it's £15 each way.
Now depending on how you're fixed geographically, that might be fine. However, if you have an Adams/SGS/other rental free gas company agent within a short drive, it makes them worth thinking about even if the deposit is a bit more and the refills are more. Apart from the maybe £30 on top for sending bottles across the country there's probably less hassle in driving a few miles to the agent.
You really have to look at all aspects of these rent free deals, some have a straightforward deposit, some have a declining deposit so after maybe two years you won't get any of the deposit back. Some have a right to use the cylinder for some years, with some you buy the cylinder and in one case a shipping case for it. Some have agents all over the country, others don't. They fill to different pressures. Some include a regulator with the cylinder. They fill to different pressures.
The Vollzone deal is probably the best if you use a couple of 20L cylinders a year or more and you are confident you are going to do that most of the time.
Just about any rent free deal has to be better than disposable cylinders even if you don't do much welding in a year.
So I reckon SGS is the one to go , they have quite a few distributors within a few miles from my home.
Yes there's all sorts of stuff to take into consideration with gas suppliersand you need to read the small print, although they're usually quite open about what their deal is.
Don't forget that SGS offer forum members a cash discount on their first bottle, which I think is £10 for a 10L and £20 for a 20L, which is nice. The details are on the thread in the shielding gas section. Basically you send him a PM and a copy of your receipt in the post and take it from there.
Get yourself a peashooter flow gauge to make sure your gas flow isn't too high and wasteful.
http://www.weldequip.com/gas-flow-tester.htm
Between £5 and £10, depending where you buy them, but worth every penny. 10lpm is reckoned to be right for MIG but you can sometimes tune it down if you are out of drafts. Better than listening to the torch or dipping it in a jam jar full of water and guessing.
i was in the same position as you, i thought i could run a good weld, i first ran a seam on new metal 1.2mm then i butt welded 2 pieces.. tick! then i plug welded... tick! then i thought about the welding i actually need to do on the car, and some of it is lap welding, new metal to thin old stuff. I had a bit of sill that i had cut out of the car, but was in decent shape, so i got a new piece and i started practicing lap welding on the bench and i started blowing holesConfidence went from 8/10 to about 5.
Get as much practice on as many different types of welds that you can before you start anything on the car.
