Noods
- Ipswich
Lower two beads with 1.6 mm rod dipped gas same electrode amps set at 60amps .. The last pic shows the reverse side of SS..
X NöODs
Cant believe its from the same tig as the ones you have shown before.
Doesnt seem to be any gas issues, or other at all, there.
Very small piece, beads close and you still have some colors in it. Well done mate.
Makes mw wonder if you have been trying on cast iron or some dirty steel before![]()
It must be me going wrong then when I try to make joints in steel then... Unless there was a hole in that pipe all Long and I've only just found it..Nothing wrong with them beads mate.
That's a new hose crimped on.. Richard asked me to run a couple of beads on ss without rod when I got it fixed ... ( replaced by me not at any workshop ) haven't felt up to it till now tbh .. XIs that with the new hose or the one with the pinhole in it?
Yep ... I will do that in the morning when I get home mTe .. Beads on plain steel with two diff rods.. Will post on Forum ASAP ..If you just move to 2mm plain steel with the very same settings what happens then?
Try both your ss rod and mild steel.
On edit, didnt see that you fixed your hose. That might be the big thing...
my esab only has 1 yrs warranty and therefore is out..
Yet on esab website it says 3 yrs?
Will do mTe ... Will run more on steel too so you can all see... I guess if they are ok it's down to me or possibly the pipe with a hole that's in for a kicking then.. Just remember your talking West Ham here with mtes in the ICF.. So you'd better get your DMs on and tool up! .Noods those ss autogenous runs look clean mate. Linish them off inc all the heat tint and do it again and again. If results remain consistent your buddy is top notch. If you can't get the results on steel then that's a different problem and you need to not pick on that little yellow box any more.
Bully![]()
doesn't the sales of good act says items need to be fit for purpose for 6 years in England and Wales. ?
Not the pipes fault mr West Ham.Will do mTe ... Will run more on steel too so you can all see... I guess if they are ok it's down to me or possibly the pipe with a hole that's in for a kicking then.. Just remember your talking West Ham here with mtes in the ICF.. So you'd better get your DMs on and tool up! .
