Hello all,
I'm in the UK and have picked up a welder generator badged as a "Lyte Arc", some googling has lead me to believe that it's actually a Miller roughneck, however I can't find a serial number and was hoping some of you would be able to help with ID. Apologies I only have a couple of photos of the control panel, Ill get some more and post them up tomorrow
The engine is a Koehler 12hp and the max current is 250A. The power side is labelled as 115V at 60Hz.
Aside from ID I have a couple of other questions:
1) Will UK made 110V tools be okay running off this generator as we generally use 50Hz rather than 60Hz?
2) If I reduce the engine revs by the correct factor will the Hz also drop? Letting me achieve the correct frequency at the expense of some power...
3) What types of lighting would be happy running off the connection labelled 150Vdc? Is this just rectified 115Vac?
Many thanks
Michael
Many thanks
Michael
