My dad has some LightwaveRF switches in his house, the specific one in question is this:
http://www.megamanuk.com/lightwaverf/products/dimmers/jsjslw440wh/
3 of the switches are used for ordinary downlighters and work fine, however he wants the one of them to activate some RGB LED lights. This is a problem because the switch requires a trickle current in order to activate itself, the LED driver does not allow this.
None of that is the problem, I've got around that by using an AC/AC relay to switch another supply for the driver, that works, but by itself the trickle current from the switch is enough to activate the relay. I've got around that by wiring a bulb in parallel with the relay and the switching side works fine but he doesn't want a light on in the cupboard where the relay and the LED driver live all the time the LEDs are on. So, how do i replace the bulb? can i just use a 230v resistor across the relay contacts? if so what size and spec do i need?
