Ben88
- Lancashire
I've been asked to weld up a 304 grade stainless steel exhaust system for a car he has all the parts ready to go. I've got a lot of welding & fab exp just never done exhausts, he knows this by the way i've been praticing on some scrap material an feel good to go. I was told by an old timer at work to use 316 filler as it has better corrosion properties does any one else agree with that or is 304 filler good enough. An Purging do i need to do this? He says you don't need that much penetration, but will this not cause sugaring on the inside of the weld? thanks for reading
) bend it so it fits the internal diameter nicely and use that to seal the back of the weld when welding - stops air getting to the back of the weld - make it in two halves (180 deg) easier to get out afterwards.
