daleyd
- Wrexham, North Wales
It's easy enough just to stand on the bench to change the spool.
With your harness on and working at height permit signed off of course ......
Some use 250kg drums sat on the floor but obviously they have to feed the wire a long way. The wire wizard helps.
Its a wire feeder that sits on top of the drum and "pushes" wire along the conduit to the WFU.......lots use them. Air Driven so can slip without troubling the motor.We did speak to Lorch about using bulk feed packs but quarter of a tonne of wire would take years to use up on that, plus more expensive.....and something else to fall over.
What is a wire wizard?
Actually the wire is better in a drum. You dont have the cast and helix, its basically straight so less spinning and misplacment.....so it suits robots
Fall over?........you need to do something really stupid to make one fall over......
How much is a lot of changes though? I have never been on a job were people changed a great deal. When that did occur it was more by wire type
So what is a lot of wire swaps for empty to full anyway?
There was a "data sheet" from Lincoln showing the savings in time (and time is money)........I wrote itI'm going to do some sums and see how much the saving is to switch over to the pay-off packs.
I expect it's significant if roll changes are regular and knock on effects like better feeding add up to a better overall result.
If we ran a robot on 15kg reels they needed changing once a shift!
Probably still available Al, I'd say a wire spool every 1-2 days is a lot.
Let's say 2.5 spools a week.
4 minutes to wander off to the stores for another, wander back, remove old roll, fit new one, fiddle with tip, realise it's still hot, wait a bit, chat to colleague and stop him working...
That's 10 minutes a week, 48 weeks of the year, 8 hours lost per station, times that by however many guys you got...
When I was on peace work making agricultural equipment like cattle crushes and the like , you could use a reel a day and I can tell you that the 10mins or so rest while going to fetch and change was more than welcome.
