Springerdinger
memoirs of the mediocre diy mechanic
- UK nr Southam
It's a Ryval mma arc/tig 170Mma?
Far left, too much filler/not enough heat/travelling too fast. Other two are getting there, although I can't see an enormous amount of detail on my phoneTonight's effort
Having looked again, far right is getting the idea, a bit more consistency with the filler at shorter intervals and you'll be away
If it's a small piece that's becoming quite heat soaked it can cause your welds to sink. Allow it to cool a little and work on bigger bits.
May be the first thing to get right is to be able to have a proper arc : you will mess up the tungsten many times and the arc is rubish as soon as the tungsten tip is gone by touching the metal or puddle. There is no point trying to continue welding after destroying your tungsten when you try to learn TIG welding: and yes most of your time is spent on grinding the tungsten.
Also there is a specific way of grinding the tungsten and what are you using to grind the tungsten: a suggestion is to use an angle grinder with a new flappy disk that is specific for grinding the tungsten so that no other iron dust can contaminate the tungsten.
Also the angle is quite important: you need a pointy sharp tungsten for lower amps as in your case
Make sure that you tungsten looks like new including the rod itself. Learning how to grind a tungsten is very essential when learning. Welding is going to be a whole lot easier when your tungsten is almost perfect: you will notice that the arc will be very steady instead of that it is wandering around.
The arc wanders a bit around the first few seconds until you have a proper puddle. After that it becomes a steady nice looking arc that is very steady.
Also don't burn your tungsten when grinding. make sure that the shaft or rod itself is not contaminated.
Last suggestion is to write down all the settings and angles of torch and tungsten shape and in the end write down what happened : what went ok and what went wrong.
