addjunkie
- Northumberland. Reet oot in the sticks
erm look again at the post
Hardly. Boats in that condition are being gifted. A new hull and deck moulding would be more than one could buy a boat in good nick with an engine.I think I should have looked into buying a new bare hull before taking that one on. You have a lot of guts I will give you that
Nahh they paid to have it removed
Brave shout though
Mate needed to wrap copper pipe round a tube as part of an exhaust system on his classic boat reno. Think the tube was 15mm. radius about 30mm. He filled it with water and put it in the chest freezer. With the ice in it, it went round nicely by hand with no kinks for about 15 turns.
I have a home made version of the MM bender and made some curves in 19mm SS tube with a fabricated former and a delrin roller to pull it round. Acceptable bends with no kinking, but slightly flattened.
Nice job on the boat Wully. You were effectively starting with a hull and deck. What engine are you planning on?
Funnily enough, I am just finishing a 24mtr rail al round a boat in 40x20x2 mm stainless tube. The very tight curves are pie sliced and welded up (talking 2" rad) and the gentle ones along the boat are formed by gentle kinking every 100mm in the hydraulic press (like a cross-bow bender) Couldn't do it in the section roller bender, as the curve varies along the boat.
i have a pair of them here somewhere but im with you on the downsides of them too, i was only thinking outside the cheap box tbh.i wouldnt use that spring unless its the last thing that i could use
ive bent 15mm not a problem often and sometimes got that spring stuck in it
same with 22mm bending around the knee
32mm is a swine to bend over the knee
In a way yes as it cost to buy it lol. Brave or mad as some say, its a hobby, much the same as all the cars i have bought, and other boats, not a car yet has needed fixing in one way or another. This boat cost me £250 delivered, not bad if you now the cost of boat transport.
No chance, cost way more.
Hi mate, I am a Marine Engineer and hydraulic pipe fitter. For thin wall stainless tube do not buy the hydraulic 12 tonne crossbow type as in Clarke etc. They are for heavy walled steel pipe. You need a tube bender so pipe is supported between former and guide for entire radius of bends for crinkle free forming. I think you can see from below I know what I am talking about. I piped this beastHi all, i am not far off, well this spring to need to start making the hand rails and bow rail for my boat. I will be using 3/4" ( 19mm ) polished stainless tube with a 1.5mm wall.
Now the idea is one i have seen using ally channel to make a kit car window frame.
Plywood 18mm to rest the tube on which has a radius of 3" ( 75mm ) then either side half way up the tube height again 18mm plywood, so sits about 10mm above the central part, then a madrel to form the tube around the radius, this way the tube will not splay out.
Now not sure if it will crinkle on the raduis.
Your thoughts![]()
W.olly.....i am a time served marine engineer, i have worked or played on boats for 50 years, your a braver man than me taking that on. I started at 4. And yes i do know how much boat transport costs.
Now to engines. Fitting an inboard isnt so difficult, can be done quite cheaply if you marinise a diesel, theres plenty info on line. The hardest bit is getting it all to line up, but even that isnt so difficult with patience if you set your bearer beams in the correct place.
Leave 2 stroke outboards well alone, they will be dated no, noisey unreliable, un economical things. If buying an out board make sure you get the prop and controls with it, if you dont get the controls theres a good chance it is nicked. Controls and cables are bloody expensive, as are props. With props check the pitch, higher the number, more top speed less acceleration. Make sure the boss is correct to there are a few different ones. When fitting your outboard it needs to be slightly off center to allow for the throw of the prop, or the steering will be very heavy one way fighting against it.
Now some advice i was given by a multi millionaire boat owner, I assisted with some jobs, hes a family friend, no money changed hands. "If it flys, floats or f word meaning to have sex, it should be rented"
I made a bender for 19mm tube something like 2mm wall thickness and used it to do a 3 inch radius on my go cart I made, had inch and 3/4 inch tube in it, sure I posted some time ago, but anyhow here is a picture or two of the kart so you could see what bends it would do.
And the bender
It sits on top of a Clarke bender stand but sure you could fasten to something else if you wish to try.
You are not a million miles from Blackburn if you wish to borrow it or come up and try a bend.
Sure I could find the formers.
Adrian
Hi mate, I am a Marine Engineer and hydraulic pipe fitter. For thin wall stainless tube do not buy the hydraulic 12 tonne crossbow type as in Clarke etc. They are for heavy walled steel pipe. You need a tube bender so pipe is supported between former and guide for entire radius of bends for crinkle free forming. I think you can see from below I know what I am talking about. I piped this beast View attachment 80132 View attachment 80134 View attachment 80134 View attachment 80136
