Isn't the frame just mild steel? If so why not just use normal mild steel?
Clean the crack up and weld but first; as said chassis is mild steel and it should be fully welded or may fail a future mot as chassis has to be fully welded
Do they have the same mot system as us in Poland?
You had the advantage on me there, I'm on my phone and never saw locationDo they have the same mot system as us in Poland?
So am I...rotate 90 degrees...You had the advantage on me there, I'm on my phone and never saw location![]()
Yeah I know, I just read I never gave thought to itSo am I...rotate 90 degrees...
Yer it is
What year is the transit Jack?
From what i was told,if it moves then stops it passes
couple years ago it will pass , but not now...With a fairly bullet proof engine, very reliableEarly Mk5
Those are becoming like rocking horse poo jack look after it,is it a tipper?
Run of the mill mild steel will do you,just put a good protective finish inside and out afterwards
I want to bend 2 angle and weld it to frame
correct me if im wrong but it looks to me like the op intends to do a bolted repair only?
The holes are probably for plugs welds.correct me if im wrong but it looks to me like the op intends to do a bolted repair only?
Early Mk5
2.5TD 100HPWith a fairly bullet proof engine, very reliable
