Hi all,
New to this forum and although I'm based in the US, I'm a Brit and have enjoyed reading this forum. So sorry for the references to fractional sizes!
I've recently started MIG welding for my Porsche 911 restoration project: typically 18/20 gauge sheet metal in butt-welds or plug-welds. I have one situation where I need to weld 2 components of very different thickness and was wondering if I could please get some feedback on the best approach?
There is a series of threaded "bungs" which comprise the pickup points for the front suspension and on the panel which I bought, they were only welded on at 2 points around the circumference. I would like to complete the "seam" to give it more strength. The base of the bung which I'm welding to is basically like a 3/16" thick washer (4.8mm), and the sheet metal it gets welded to is around 18 gauge (1.3mm). Should I set my welder (Hobart 140) to the suggested setting for 3/16", focus the puddle on the bung and then give a quick swipe to the sheet metal? Or will gravity let the molten puddle trickle down onto the sheet metal and give sufficient penetration without blowing a hole? My main concern is blowing through the thinner metal.
My other question is how I should weld the seams without warping (since the position of the bungs is important to the suspension geometry). Should I make 2 more tacks and then weld continuously in between all 4 welds?
Many thanks!
Many thanks!
