BrokenBiker
- Newport, South Wales
right, i have a limited knowledge of brazing/silver soldering...
i did a bit of it as an apprentice on small parts, usually things like a steel part that had been snapped and for what ever reason it wasnt allowed to be welded, usually becasue it was either hard or cast iron, so it was brazed/silver soldered.
the technique used was to drown the area to be joined in flux, get it good and hot with the oxy acetylene then take the flame away, dab rod in until you can see the braze/solder flow into the joint becasue of the capillary action...
i thought this was the only way brazing with a flmae was done, and then tig brazing was just like tig welding but without melting the parent material...
anyway, watching a video by Abom79 Here and the way he is brazing just looks like oxy welding to me...
can anyone explain how this differs from the method i described above. more of a curiosity than anything i am looking to do but once i have a decent sized workshop/garage i may be interested in brazing
