premmington
- Norfolk
Had a play today.
Arcair Slice
Arcair Slice
If there are no pictures it did not happen.Had my first play today.
Arcair Slice versus old digger pin stacked on concrete blocks.
A bit nervous, 45 seconds of intense heat and sparks.
A bit more practice required to keep the rod moving to prevent sticking needed.
Arcair slice isnt a thermic lance...........the TL is a steel tube filled with lengths of steel wire and its threaded at one end
With practice you should never need to clean up the bores after lancing.
The idea is to remove the Middle of the pin so it can shrink much more on cooling than normal, this allows you to withdraw the pin.
I'm not sure how the Arcair works but a normal thermal lance doesn't use any electricity.What is the difference between an Exo thermic cutter and a Themic lance?
I'm not sure how the Arcair works but a normal thermic lance doesn't use any electricity.
You could be right - ours was for marine use so I think it was able to be used by divers/ underwater if needed (hence the vest arrangement). Trying to spark up an oxy torch underwater would be bothersome to say the leastSoMe lance torches have the option to use a battery to initiate an arc and begin the process.
However- I've only ever used a oxy fuel torch to start burning the pin then hit it with the lance. The battery set up has always been a bit fiddly in my eyes.
So there is a difference between a thermal and a thermic lance, I'd always thought they were different names for the same thing.Sometimes you add some aluminium wire to get the THERMIC REACTION going...
you didnt see nufink rightWere they not the weapon of choice in various bank heist films of the 70s?
