slim_boy_fat
- Scottish Highlands
Following advice on here, I now use three anodes to surround the work piece - much more efficient than one big one.
i have a lot of stuff in my head but some of it mightnt be in the right file so to speak but am i right in saying that you can use solid carbon as a sacrificial piece or have i that confused with some other plan i have on file up there.Following advice on here, I now use three anodes to surround the work piece - much more efficient than one big one.
as pdg says its the optimum sacrificial piece to use just, i mind at the time some on you tube were using it and the results were good.Not sure, but why reinvent the wheel?I use an old lawnmower blade and some scrap steel rod/bar.
I thought sodium bicarbonate was a no no. Happy days, if it works I've got plenty of it.
i was collecting a sandblaster from a place last year, a clear out sale so everything was going.Yes, you can use carbon.
It lasts way longer than a lump of steel, is easy to clean the gunk off, doesn't degrade in the same way...
The sole downside is the price.
There are a few things that just aren't worth experimenting with - table salt, stainless electrodes, cyanide (yes, it works, but really).
What's the issue with stainless electrodes?There are a few things that just aren't worth experimenting with - table salt, stainless electrodes, cyanide (yes, it works, but really).
Stainless releases hexavelant chromium as a byproduct of electrolysis.
That cleaned up nicely. Looks like a useful little vice.Here's one I did today.
It was firmly attached to a Meddings pillar drill I just bought.
I took one look and assumed it was skip fodder.
But after a couple of days in the tank...
Don't leave it around when wet. It will rust solid.
Blow dried.
It's not a great tool. Made in Taiwan and I'll need to replace the plastic handles. But it runs smooth enough now.
S.
Blow dried.
S.
Doing something that size would be a bit of a problem in Phosphoric acid so I can see that is one benefit of Electrolysis. When I have done seized hose clips etc they have been really free once they come out of the acid, I assume its the same here?
D
its a while ago since i seen a can of duckhams oil be it empty or full.Here's one I did today.
Blow dried.
S.
