balmerchris
barnacle picker
- Co. Armagh
How would I go about reading amps on this multimeter
Can you not read AC amps?You can read a maximum of 10amps DC, set it to 10A, black lead in common, red lead in 10A and the probes in SERIES with your load.
Put the red probe on the plus of the charger and the black on the lead to the anode, the current comes out of the charger, through the meter and then into the anode.ive got my battery charger running on an electrolysis tank, how do i do it in series?
Doesn't look like that meter can - the gauge only has settings for DC.Can you not read AC amps?
You can but not with that meter, the solid line with dots under it next to the A range shows its DC. If it was AC it would have a wavy line.Can you not read AC amps?
Not on that meter because it says DC next to the terminal.
Disconnect the + wire from the bath and connect it to the 10A DC terminal then connect the black lead (COM) to where the +ve was connected to on your bath. Set the switch on the meter to 10A then switch the power supply on.
Are you sure the bath isn't taking more than 10A?
I was doubting myself...lol I had not looked at the actual meter.Doesn't look like that meter can - the gauge only has settings for DC.
You can get meters that read AC current, tho.
might just do without knowing then. dont want to break it.I would expect that a draper meter will have a fuse inline with the current probe socket, so I would presume that the worst case is that this fuse would blow.
But I'm not buying you a new meter if I'm wrong
Edit: The meter explicitly says it's unfused, so disregard the above!
You can get a new meter for £10 so I can see why you went aheadI done it anyway and its reading 1.90 amps at 10 volts.
Yep, that sounds good.Does that sound ok to anyone who has used an electrolysis tank before?
