Parm
Respect The Sound System
- Towcester
im the last one at the end of a drive way that then eventually turns into a bridal way. It's shared by four other houses.
It's basically mud and compacted gravel that's mostly gone
Over the hols all neighbors have agreed that it needs to be made good and consensus is that it should be covered with 20mm shingle stone in keeping with others in the area.
I've got a good deal with a local supplier at £23 / ton delivered and he will reverse his waggon to the end and drive forward while tipping thus saving loads of work.
Now how much will I need and what is the recommended/optimum depth required? The area to be covered is 60 metres long and 3.5 meters wide
If you can get some road planings you can make a good surface by sprinkling some diesel on with a watering can and rolling out with a vibratory roller or a whacker plate. A farm we camped at a couple of years ago was doing the yard and it left a good surface for traffic.
