flyingbenny
New Member
- Mid Wales
Afternoon all
I found this site yesterday when searching for some answers on what to do with my poorly mig, there's a lot of knowledge on here so hopefully someone will be able to help me out.
I was given this little welder a few years ago and it has been brilliant, I've used it restoring a mk1 escort van and other small jobs and it has never let me down. Not until a couple of days ago anyway, I was doing some repairs to a trailer so swapped from 0.6 to 0.8mm wire and had it turned up higher than usual, again it was welding a treat until it just stopped. The fan still runs but nothing else.
This is the welder, I have no idea what make it is and before everyone starts I know its probably only a cheapo thing that is not worth doing anything with but as I said it was free, it's done all that I've needed it to and for bodywork its been great. I cant afford to change it for 'one of these' or 'one of those' so if there is a way of getting it up and running again that would be great and I would be a happy man again.
And this is what the back of the pcb looks like, I'm mechanically minded but not electrically but even I can see that doesn't look right and guessing this is what's causing my problems??
That is on the back of this black part circled:
I know it's a bit heath robinson but could I repair the damaged section by soldering in a link of wire to bridge the gap? Is the black thingy (relay??) likely to be fried? Does anyone fix these? Would a board out of something more common fit??
As I said I'm not very electronically minded but I am practical and if someone could say try this or try that then I would have a go.
Apologies for the miss match picture orientations, they were all ok on the pc
Thanks in advance guys, I hope I can get it running again, although the guy who gave it me did say 'I guess you'll want my Kemppi now then?' so perhaps I'm better off leaving it broken!!
Cheers
Ben
Cheers
Ben
) I would definitely start with that relay.
