If they made them solid they wouldn't rust away causing heavyAnti vib balance lump/ harmonic damper possibly?
usually on suspension axles--- x/members etc to stop harmonic vibration or panel flex at certain speeds it makes me laugh they make cars lighter and lighter but then they rattle, so they stick on massive weight's
around the cars to stop it vibrating. Thus piling totally unnecisary weight on again, why not just make them solid in the first place.
are you sure its from your car ? it could have bounced under there from a passing car, they don't usually fall off 5 year old carsIt has a metal core, weighs over 500g and fits in the palm of your hand. The car is 5yrs old.
In the secong picture there looks to be possibly a wire broken off below the surface??
If it had not had the rubber backing I would have first guessed at the metal backing plate off a disc pad with a wear sensor.
How thick does a brake backing plate need to be? thats as thick or thicker than it is rectangular by the shadow it is forming I am guessing 100 mm x 60 x 80???
Got to disagree on this oneHow thick does a brake backing plate need to be? thats as thick or thicker than it is rectangular by the shadow it is forming I am guessing 100 mm x 60 x 80???
I think you are Steve considering it is is laid on its side in one picture and stood on its end in the otherGot to disagree on this one
5mm at most, shadow caused by a distant low lamp, we need better photos.
EDIT: Just seen the 500g weight mentioned, looks like I may be wrong![]()
