Am currently welding 10mm plate and H irons together to make a shed. Am using about 230amps so plenty of heat. in fairly new to mig but all the welds are nice and clean and look fairly good. my biggest worry is if i am getting enough penetration. im welding the plates at both sides and also grinding back the metal at the end of the joint. So is there a special thickness of weld i need to put on, our is everything okay . also at what angle and movement rate gets the best penetrations
thanks
thanks
