GW8IZR
Gone.
- Anglesey
Hello, new to the forum and my 1st post.
I need a tig welder ... now my wife would rightly transpose need with want but that's the way it goes ;-)
The job is a bit of small fabrication, brackets clamps and frames etc to support other hobbies but I do need to be able to weld thin aluminium.
I think a fairly small ac/dc tig would do the job but recently I bought a small plasma cutter and thats led me to question the quality of the entry level sets. Just moving up to the next size cutter meant the torch was an order of magnitude nicer to hold, better finish and generally the function / use was better. Note thats not using the extra power available.
Is it the general way of things that if you buy an entry level tig from any of the 'reasonable' suppliers TA / R-tech etc the quality isnt as good as buying from the same supplier but just a bigger unit?
I'm not going to be buying a no support ebay special but also I'm not saying money is no object, but if a slightly bigger unit was much better then I'd find the funds.
Any advice - thank you.
Regards Paul
Regards Paul
