Hi everyone!
I'm getting very stuck into my trailer project but I'm having real issues with my chop saw. Some angles it cuts fine, others it WAAAAAYYYYY out.
I'm cutting 45 corners to make a frame from 50mm box, and whilst most are there (or there abouts) that can be made to fit with a small root gap at one end or the other the short peices are causing a real problem.
Becuase they are short the clamp doesn't hold them, so I hold them by hand, and the inevitable twisting happens.
My question is - how do you fix a peice of metal that has cut like the picture below? If I try to recut it the chop saw just follows the same path becuase the disc has no strength against side to side motion, and I can't turn it the other way and cut from the other side as the chop saw disc isn't big enough to cut - plus it will just be as inaccurate even if I managed to use the extremitiies of the disc.
What do you guys do? and how would you fix this cut?
if i'm a bit off the mark ,(on my bandsaw)i've used flat steel to extend the working range of the vice,usually need a small offcut or adjustable screw at opposite end of part being clamped so vice doesn't twist or, tack weld short pieces to other material and use vice normally then cut off and dress with grinder afterwards,would also recomend cheap combination square and scriber some clamps and even jig magnet ,sure u will use them for other projects as well
.hope this helps.......
