Spark plug
- Durham, England
im makeing some forgeing dies to go in my fly press:
I've made them from some old rail track witch from my reasearch I'm guessing is about 0.4-0.5% carbon.
Looking at the carbon content I've compared it to en45 Spring steel and found this information on hardening and tempering it:
Hardening
Heat the steel slowly to 650-700°C and thoroughly soak. Continue heating the steel to the final hardening temperature of 870-930°C and allow the component to be heated through. Quench in oil.
Tempering
Temper the EN45 spring steel immediately after quenching whilst tools are still hand warm. Re-heat to the tempering temperature then soak for one hour per 25 millimetre of total thickness (2 hours minimum) Cool in air. For most applications tempering will be between 400-550°C.
Does this sound about right or not?
I can get hold of a gas forge for the job witch should be easier than trying to do it in the coal forge but 2-3 hours to temper is going to be a lot of gas.
Any thorts?
Hardening
Tempering
Any thorts?
