TBH it's not very important to level it, wear and operator error will exceed the variation the unlevelness may cause by some margin.
Operating a lathe when the ship's bobbing about like a leaf in a storm drain is not at all like making love to a beautiful woman, it's all about avoiding getting wrapped around the spinny thing or driving the tool into the chuck.
Otherwise I'll use my relatively new builders level.As has been stated the Boxford cabinet is a strong affair
As long as it is sitting on all 4 "feet" it will be fine
I have video on the lube of your lathe it may help you
Sorry Pete, missed your question, 4 feet.Is it bolted to the cabinet with 3 feet or 4?
Great vid pdg, many thanks, such a simple way to check twist. I'll also machine up a test bar when done.
I know it's probably over kill but at least I'll see if the lathe is worn and it's all good experience anyway.
Thanks again for replies so far.
Anyone else out there using the quick change Chinese tool posts? Any recommendations?
You normally just need to machine up the block on the bottom of the central spindle to fit your machine. If you buy one, replace all the cap screws with decent non chinese cheese ones.
Easy enough to fit, once you grt one in your hand itll be pretty obvious
That's the one I bought. Exactly the same as the offering from Arc, but as they are just around the corner I saved a bit on P&P. Regarding the bottom plate, I made a new one as the one it comes with is hardened. AS far as buying some extra holders, I'm quite happy to share a batch, but I won't be doing anything until the New Year. I'll make a note to check out prices and PM you when I know. GrahamBeen poking about the net a bit and seen this type demo'd
http://www.amadeal.co.uk/acatalog/Quick-Change-Tool-Post---Piston-Type-AMA_AC_251_100WE.html#SID=257
What do you think?
No I haven't , but have seen quite a few comments on forums from people that have, with no trouble.I've seen the same one on Alibaba and have requested a price from the Chinese supplier. Have you traded on their before Graham?
It's too large. Making a new is really a milling operation, although it would be possible to fabricate one, I suppose.Mean't to ask, what's the issue with the 'hardened' base? When you made new does that involve milling etc?
If you get a chance would you be kind enough to send me a picture of the plate please Graham. Just need an idea of what's involved.It's too large. Making a new is really a milling operation, although it would be possible to fabricate one, I suppose.
