When using a 7018 rod, and welding horizontally, do i start at the bottom and move to the top to prevent the slag from rolling onto the rod, because when i weld top to bottom it seems the slag smothers the rod?. any insights?
Lots of info here> http://www.mig-welding.co.uk/forum/showthread.php?t=3364
Sparkey, pipelines when manual welded are done vert down (stoving), cellulose rods for root and cap, or WPS dependent for caps?
We'll make a welder of you yet Sparkey!Ah, i see! like the welds flange jockey is doing so well? v-prepped then a first run, then filled up with a 2nd run with a big weave? (heh, blimey is that me talking??)
Sparks, if you get the time, try doing a vertical down with your 6013's. Not easy, you need to leave a gap with a vee prep, just a shade smaller than the rod, or the same. Once you get a start, and you're ahead of the molten flux, GO FOR IT!, straight down. Listen to the arc - you should hear it breaking through the other side.
Then try it with 7018/6's, and 6010's. Very different, much easier.
I love going vertical down. Looks a treat when you get it right. Up is easier though - well - different. Maybe it's not a matter of easy/hard. Just different techniques for different things.
Si
You sure know how to motivate people, or does it only work on girls? You bet i'm gonna try that! reading your post gave me the welding-shivers....wer's me rods???
try using 7048..
