MoreWellie
- Warwickshire, UK
I am looking at making longer ramps where the slope is detachable and wondered if anyone tell me simply how to work out how much weight the slope could take
I am thinking of making ladders out of 50x50mmx6mm angle with 5mm cross flat cross braces out of tread plate (because I have these) I would also have to add some smaller angle across between the two rails every so many tread plates to give some additional strength or even make all of the cross braces out of say 25x25mmx3mm
If I made a straight ladder frame about 1.8m long is it a simple calculation to work out what the maximum weight I could put on the middle if it was supported only at the ends?
would it make a difference to the maximum weight if the angle was up or down?
I could obviously go belt and braces and make a support frame but that makes for storage issues when not in use so I wondered what the capacity would be without the frame
