scotto75
- Bristol
I'm planning on making a battery box for my bike build that is welded to the frame. I want it as light as possible ideally, so have thought about making it in 1mm. I have no tools to bend or form, only a welder angle grinder and a big hammer. My initial thought is to cut the base and fur sides and very carefully weld them.
The main consideration is that top of the box will be open and will need to be the exact shape of the aperture in the frame, so that it can slot in and marry up to the frame in order to be welded. The base will be the exact shape of this aperture. I'm not sure if welding the sides to the base will mean by the end the top will fit?
Is it possible to weld a box with a base and four sides out of 1mm without it warping or is there a better way to make this without involving any specialist equipment?
Thanks!
Thanks!
Been looking forward to welding some more stuff!
