Hi guys, almost finished build my shed/workshop
Just after a bit of advice when putting the floor in. I want to use t&g chipboard flooring because it will be thick a strong and easy to lay.
Now my base is sat on concrete blocks above ground level and stones laid on the ground so the frame has good airflow underneath.
Should I put so damp proof sheet barrier between the floor and the base/beams or just lay the boards onto of the beams?
