Hi i use rota broach cutters in my pillar drill i have used a 22mm which works great cuts perfectly but i have a 50mm which vibrates the drill and chatters i don't really get swarfs coming off it just small scrapings.
Do any of you know why? the only thing i can see different is that the adapter i have has 2 screws to clamp the cutter in and majority of my cutters have two flat surfaces but the 50mm cutter has counter sunk holes that's the only thing i can put it down to.
I am using the cutters at 160rpms and the other cutters work fine, i turned the speed up to around 400rpm and it didn't make a difference 50mm still chattered and the 22mm still cut perfectly.
Have any of you experienced this???
