Hiya all. New to forum was looking through google and came across so thought id join and need help
Ive got a clarke 235 mig i aint had it long and was working fine. Came to use tonight and seems the wire fèed isnt working or motor. So i slakend off the the tension to see if it spins and it does oh so very slightly.
Ive just taken motor out and tested on a car battery and motor seems to spins nice and freely.
Any ideas? The relay on the board is clicking and can see it moving.
Cheers all
Cheers all
) If you removed the motor from the gearbox to test on the battery then you MAY have a problem with the gearbox. If you tried on battery the complete motor AND gearbox then you have a lack of power to the motor. This may be from the contacts on the relay being carboned up causing resistance to the feed to the motor even though the relay is operating. It is possible to remove the cover from the relay and as a temporary fix you could use an emary board (type for filing your nails) to clean the contact faces of the relay.
checked all wiring ect and noticed i didnt put the inline fuse in its holder correctly as i took them out to check if was ok. Pushed back in and all is good.
