CompoSimmonite
When I built my carport I stopped half way down the side of the house due to back door and central heating balanced flue. Now it's been decided to move door position ready for a conservatory at a later date so there is only the boiler flue that stops me expending the carport the full length.
I should add boiler is going to be changed at a later date for a modern unit with ducted flue so won't be a problem in the future.
However back to present
The flue is 1m from the corner of house measured to centre of outlet.
I can design carport extension so it JUST comes under the flue lower edge however intention is to leave a big gap around this flue pro tem that can be covered at a later date when new boiler fitted.
Plan therefore is to make a galv steel "duct" that is, say, 30cm below lower edge and open to the corner of the house plus around 60cm to the rear. This will be fully sealed so fumes can't enter the carport.
The original installation instructions for the boiler (I've got these even though boiler is 35 years old - what can I say "I'm a hoarder"
) simply state must not be installed within 30cm, measured vertically, of an opening window, not immediately below eaves or balcony, less than 60cm from any surface facing the flue. There are no requirement or specifications given to what clearance there should be around the sides of the flue.
Do people think the duct idea is sound ?
I know the proper answer is change boiler first but that simply isn't going to happen for probably another year and I want the carport extension built before this winter.
Cheers.
Paul H
) simply state must not be installed within 30cm, measured vertically, of an opening window, not immediately below eaves or balcony, less than 60cm from any surface facing the flue. There are no requirement or specifications given to what clearance there should be around the sides of the flue.Do people think the duct idea is sound ?
Cheers.
Paul H
