Mick B
- Orange. NSW. Australia
Sometimes I find it easier to draw a picture rather than try and explain what I want, so ........... I was welding some 35 X 35 X 2 mm SHS in a butt joint (flair bevel ?) today and wasn't too sure which way to go about the weld. I ended up angling the torch as in "A" because I thought if I used "B" it might put too much heat into the open end of the piece on the right hand side and maybe blow through it.
Am I on the right track ? It seemed to work OK.
Another question while I'm at it, I didn't weave the weld (as in little eeee s or zig zags) I just ran the bead straight. What is the advantage of weaving anyway, just to spread the heat, or does it make the weld stronger ?
