probably better to warms up the garage a little, a soon as you paint, the air blown onto the panel will probably make it cooler then it was before paintingyes use the fast but you still need to keep an eye on the temps , its getting pretty chilly here overnight
even its ifs 10 mins spent with a heatgun getting some warmth into the panel
painting front and rear wings doors, that are off the car, then whats left on the car ( its a roadster so no roof ) what would you recommend ?what are you painting ? wont make much differance for seperate panels , you wouldnt want to do a shell with it
I wouldn't it will go off quicker he already has very activator and it will slow down or stop the paint flowing giving a worse finishHeat your clear and hardener in hot water before using it.
it will start to go of quicker in the gun when mixed, as soon as it hits the air cap and is mixed with air it will be as cold as the air from the compressor so a total waste of timeWith these very cold nights we are having the clear will be very viscous if left in the garage overnight.
I can see it would make it thinner but so would extra thinners, as for temp it would be cooled straight back down as soon as mixed with airWhat do you think of this guys comment?
ive never used very fast, only fast and have used heat as well so with no heat you should be okIs it worth me nipping into town and getting normal fast hardener? I'm just worried I won't get a decent finish
why stay away from rocket? ive used it several times with no problems???
