Richard.
- Cambridgeshire
Hi mate. It's a good q. I don't know the depth of penetration you'll get on it. It won't be a lot. In a joint you can control penetration and get full pen from low power simply with preps open roots, big gaps, small lands (faces) and IMO a 150 amp mig is suitable for a root run on a prepped 10mm butt joint. Penetration ain't the issue. It's fusion. The thick plate will suck the heat away very quick. If the heats not there then the fusion cannot happen.And I am also limited to what I can get off a 13 Amp plug, (I can change it to a 20 Amp plug as I really need 16 Amps).
So I am interested in what I can and can not do with it.
I have no 10 mm plate around at the moment so I can not go in the garage and try anything, but I would ask this question, can you not get any penetration on 10mm plate with a 150 Amp Mig or will the penetration be , of in the order of 0.5mm?? What would be expected?
Adrian
Can you imagine here heat that up for us will you? Ok I will stick it in the freezer a while
