Hi all. It's been a few years since I last posted on here, sorry....
I currently have a bloody awful NuTool mig welding machine. The main annoyance is that the wire feed is rubbish! It doesn't matter what I do it will not feed smoothly when being used. I thought at first it was me but after starting a welding course at a local college last night I have found differently. From the third run on scrap metal last night I was putting down beautiful beads of weld with full penetration. I was rather proud of myself to say the least. Anyway, this NuTool welder only cost me £50 about 6 or 7 years ago which is about its only saving grace. I did try converting to a Euro torch (it now has a proper Binzel torch) but it made not one jot of difference.
So, I would like to get a decent MiG machine that is suitable for home/hobby/diy use. It must have a Euro torch connector and must be capable of using flux core wire (I know, it's horrible but when I'm working outside in the wind...). I generally weld anything from 1mm up to 3mm mild steel plate. Usually I am working on my Land Rover hence the 3mm stuff (chassis). It must also be single phase as I don't 3 phase in my little workshop but I do have a 20 amp dedicated supply line.
What do I look for? What do I avoid? Are there specific brands to outright avoid and any to look at more favourably?
Secondly. The course I am taking will also include TiG welding. I am experienced with gas (oxy acetylene) welding so I'm hoping I will be able to pick up TiG fairly easily. I did used to absolutely love gas welding. With this in mind I ask the same as above but for a TiG machine. My requirements would be for an AC/DC machine as I'll be working on aluminium alloy bodywork (the Land Rover being of Birmabright an aluminium alloy used by Rover) and I think I would like HF start from what I have read (no fragile electronics in a 47 yr old Land Rover
Budget wise I am not sure. I fully accept that I will need to spend a decent bit of cash to get good kit. However, I don't really know what that 'decent bit of cash' is. Is there an amount that I should not go below for either machine? I don't really want a compromise 3 in 1 machine either. I'd rather get a good MiG first and then a good TiG a few months down the line.
One other option is to get a spool gun for a MiG machine and use that for aluminium work? Or not?
So, suggestions please
).Budget wise I am not sure. I fully accept that I will need to spend a decent bit of cash to get good kit. However, I don't really know what that 'decent bit of cash' is. Is there an amount that I should not go below for either machine? I don't really want a compromise 3 in 1 machine either. I'd rather get a good MiG first and then a good TiG a few months down the line.
which is why up to now I have been using fluxed wire. I could rig up a canopy but I have to be careful about not blocking the pavement too. I have just enough room in front of my house to park up the Land Rover. One inch further and it's pavement and I have been told not to block the path more than once by over enthusiastic police officers... It usually entails me having to show them the house plans/deeds.
I would much prefer to lift the body and work on it like that. not possible because of the above plus it's an ambulance body and totally different to anything Land Rover did. Marshall received a rolling chassis with a partial front cab and they then added their own bodywork. It is very heavy and like a Chinese puzzle to dismantle. Plenty of others have welded the bodywork in situ so I wouldn't be the first and it is usually successful.
