Screwdriver
Incredibly, TIG brazing seemed to work! I certainly wouldn't be so casual with anything life threatening but I thought I'd have a go.
From stone cold, 60 amps, AC, with +ve bias and -ve, seemed to go on ok but spatter.
Went to DC which was virtually the same though I think I cranked the amps up a bit. Again lots of noise, spatter and the silicon rod really would boil off in an instant. But it stuck fast! I even managed to braze it with a bolt in situ so I didn't have to muck about trying to find a hole etc. Was a right pig to get it out but it did screw out eventually.
Tidied up with a hand file. Where the TIG hit the cast iron, it went glass hard. Had to dremel a couple of spots off with a stone when I flattened it back. Drilled and tapped the back cap and all went together ok. The grub screws are only there to prevent the front jaw from being pushed into the vice, which is how the postie managed to break it when he dropped it.
Paint prep.
Last look at the repair piece.
And we're nearly there....
Just a pair of jaws to knock up.
S.
Paint prep.
S.
That's another one rescued from the scrap man.
