Folks, the work return cable on the Miller is a bit manky so I'd like to replace it. My question is, if I use 35mm2 cable, what's the maximum length I could sensibly go to bearing in mind that it's a 310A machine but I can probably only squeeze maybe 220A or so out of it? Would also probably do the MMA work lead at the same time. I think the leads are currently around 4 or 5m, what length leads do you have on your own big machines?
