3.5 cfm ishHow much air do plasma's use ? The average single phase 30-50 amp models we'd be using in the home workshop.
he might be saving up for the laser optioni wonder after all the replies to this thread the OP has actually bought one?
he might be saving up for the laser option![]()
.start savingI want a laser one now.
start saving![]()
and conking out spectacularly with a great light show, free smoke machine as standard for the showWait til the chinese/taiwanese rip off a design, they'll be selling them here by the boat load for half nothing, just like everything else.
and conking out spectacularly with a great light show, free smoke machine as standard for the show![]()
yeah they do make some good stuff, you just need to read up a bit before you buyI think the chinese have copped on about quality, after all machines like R-tech and miller (assembled in the us) are made over there and they are fine. They do knock out a huge amount of tat of course, but you don't have to buy it.
Took the plunge and bought an r-tech 30c last friday, got it delivered today. I spent the day cutting up 3mm plate, as it has 30 amps and can cut 8mm plate clean and sever 10mm (according to r-techs video on youtube) i set the amps to about half way, 15 amps or so, i wasn't getting great results to be honest, but its years since i used one, anyway being tight for time, i cranked it right up to the max and got stuck in, it worked fine then.
Try adjusting the air pressure as I find on my plasma a few psi either side makes a big difference to the quality of cut.Took the plunge and bought an r-tech 30c last friday, got it delivered today. I spent the day cutting up 3mm plate, as it has 30 amps and can cut 8mm plate clean and sever 10mm (according to r-techs video on youtube) i set the amps to about half way, 15 amps or so, i wasn't getting great results to be honest, but its years since i used one, anyway being tight for time, i cranked it right up to the max and got stuck in, it worked fine then.
Out of interest,what torch did they supply?
What drawing software do you use.?Plus one for laser cutters. These days almost everything I make is drawn up at home and emailed off to be lasered. I have oxy for heating and cutting odd bits, usually with a piece of angle iron clamped for a guide, and a metalcraft roller guillotine thingie for cutting sheet, as well as a pair of tinsnips. A plasma might be nice to have, but I would never go back from laser cutting, everything fits perfectly and it doesn't need ages with a grinder cleaning off the slag before I can weld it. It costs a bit but I save so much time and effort manhandling huge sheets of 5mm plate that its a no brainer. I just have make absolutely sure I get the drawings right!
