CompoSimmonite
I was looking at a drawing of a fire extinguisher the other day and it got me thinking.
Remove valve from a propane bottle and replace with a 3/4" Tee that is this way up I-
Add 3/4" to 1/4" reducing bush to the top.
Take a short length of 1/4" pipe (say 6" ?) and thread around 1.5" at one end and normal small amount at other.
Screw longer threaded section inside the Tee and then add elbow & tap on top.
On short threaded section use a reducer to then allow a length of 1/8" pipe to reach to bottom of bottle.
Use the side of the Tee for air in / out.
That way air pressure would push any water from bottom of tank up the 1/8", then 1/4", pipe through the elbow and tap to allow it to be drained without having to invert bottle.
Obviously it wouldn't get 100% of water out.
So what is the opinion of this idea ?
Cheers.
Paul H
Cheers.
Paul H
