ive pulled muscles humping a few old bagsDid you pull them muscles humping all them bags ?
No mate it was trying to mix a bit of concrete dry and adding water using the extra rapid cement I was giving free......lolDid you pull them muscles humping all them bags ?
It is out of date and it's extra rapid to boot. LolSome people just won't listen !
Ha , you need to be quick with that rapid stuff .
Free cement round here is usually out of date , goes off quick as a quick thing .
Could I slow it down by mixing it with normal in date cement?
Nearly finished the mortar side if things just run out of building sand and need 2 more bags to finish. But I got given 2 tons of sand and gravel and already have 15 bags of extra rapid cement and wondered if a 50/50 mix would allow me to lay it in 3 foot wide bays.If your useing it for morter just use the new stuff , if for concrete try 50/50 but you might have to get a wiggle on !
not sure. A mate of mine has been using them as tags to weld to where holes need re-enforcing .Does any one know what the large washers with 3 lugs on and an M stamped on them are for?
Muscles are much better mate. It was very strange ax there was a lot I could still do while it hurt. Breathing rapid hurt strangle. But I never knew what intercostal group of muscles actually did before I strained them lolHi ukracer, big thank you for the parcels, for a small parcel they are heavy, thanks for all you patience and time, if at the end you still/need to sell anymore I could be persuaded?
Hope muscles are improving, I have broken a lot of bones, but a muscle injury I find are far worse, having now torn several??
Thanks again much appreciated
I have only been using fresh standard cement for the block work etc.
I think I have my answer. I just laid two patches to level up some of the deeper holes. One with just the out of date extra rapid and it was solid within 10 mins.50/50 old stuff/ New cement ?
one of the lads posted so pics as he put his into storage boxes ...that might help.
OK back to the wet weather......first of all what is thisWent to cut the grass and the blade is rattling against the chassis. Took it off the motor and the split washer had disintegrated.
Went to my box of washers and nowt fit.
"Waitaminute! I've got the 20kg bag'o'bolts from ukracer in the back of the truck - did that have any washers in it?" I exclaimed (inwardly).
Yes! Yes it does! Three bags of washers of all sizes including a whole bunch of splits that fit the blade exactly
Lawnmower fixed, and I still have 19KG and 998 grammes of bolts and washers to get through - cheers, Andy![]()
