Hi all, I'm replacing the rusted out parts of a trailer floor (~2-3mm checkerplate).
I need some advice on the best way to engineer the joins. If I run into a lack of skill on my part I'll be taking the half-finished job to a pro, so I don't want to commit to a really fiddly (ie costly) approach!
Options are:
1. Simply overlap the existing plate by a few mm all round.
Pros: Sounds easy. Not too much 'permanent' welding of the new sheet to the trailer chassis. Existing sheet supports the new sheet. Minimal added weight. No critical alignment required. Can be tacked in place and then just siliconed/bogged and painted over if it comes to it.
Cons: Is it as easy as it sounds? I guess the checkerplate texture would need to be ground off the join margin of the underlying piece for a close fit.
2. Unsupported butt welds (starting at the chassis members, then tacking along the unsupported sections (~400mm) in between.
Pros: Seems the 'neatest' way to graft in the replacement sheet.
Cons: Potential for horror. My sheet welding skill is untested. Considerable accuracy required in the cutting stage.
3. Supported butt welds (welding in extra SHS between chassis members, then welding the new and old sheet edges to that).
Pros: Seems strong and tolerant of average skills
Cons: Extra work and weight. Significant welding of sheet to chassis structure will make it a nightmare to remove in the future.
Any recommendations?!
Options are:
