ime on the same hunt Stan but added complication as my Harrison is Metric..
Don't you mean metric threads? There was a discussion on the list a while ago regarding that. Apparently the difference in real life between the 63 and the 127 is inconsequential. Leadscrew wear would likely throw more error into the thread than the 63/127 aspect would.
ROOFMAN:: are you after a 63T or the 127T I`ll keep my eye open, over a few years never ever seen a 63 for sale but several 127.
The Harrison Lathe both myself and John (doubleboost) have is the 140 Model with the 36 speed Norton gearbox, easily identified by the 3 selector knobs on the gearbox. The Lathe is an all Metric machine, Dials and Harrison screwcutting information plate are all in Metric.
The introduction of the 63 translation gear allows the gearbox with the correct changewheel set up to cut imperial threads, with a range from 4 to 60 TPI. To cut this whole range, one changewheel needs to be swapped on the train. So basically 5 changewheels will cut the 4-60 TPI range, although only 4 are in use at any one time.
I dont see any problem reversing this process to cut Metric threads on an imperial lathe. Using a 63t, or a 127t changewheel -- Not having an imperial lathe I cant test drive my theory. Now a 127T is a big change wheel and comes in at over 91/4" -- can it fit into any banjo setup you have, ?????????????
Stan
...to do any usefull thread cutting i need a 100,80,60,55,50,45.
Maybe this £425 bargin was,nt so much of a bargin without a set of metric change wheels
