CRB
I gave up a week or so ago after fitting a new bottle because nothing was going right, proper stomping off angry.
So today I started from scratch and found that somehow the wire was not in the groove and thus was not feeding properly
Pulled a few feet of wire off and set the tension with the bit I cut off, lovely. I then decided to check the gas flow, for no other reason than I thought I should.
This is where it gets interesting. The regulator was set to where my 'pre-accident by breaking the other one' was set around 10lpm to give 6lpm at the nozzle. I have a peashooter flow guage.
The pea shot up and then steadfastly returned to rest each time I pressed the trigger, so I turn the regulator up....and up.....and up until it is reading around 20lpm at which point I have a reading of 6-7lpm on the peashooter.
Lovely welding ensued.
?Is it unusual to have a regulator reading so far out? It is a new bottle so I will keep an eye on it, but the same regulator was on the previous bottle for a while.
Pulled a few feet of wire off and set the tension with the bit I cut off, lovely. I then decided to check the gas flow, for no other reason than I thought I should.This is where it gets interesting. The regulator was set to where my 'pre-accident by breaking the other one' was set around 10lpm to give 6lpm at the nozzle. I have a peashooter flow guage.
