Someone has given me a old sit and ride tractor for a modest sum telling me it was in use but one day when he went to start it, it chewed its ring gear up and "just needed a new ring gear". Its fitted with a 11hp sidevalve aluminium Briggs and stratton engine with a vertical crankshaft.
Turned out to have a techmusen starter with the wrong pinion to suit the briggs motor so replaced ring gear with alarm bells sounding quietly in head, and machined briggs pinion to techmusen starter. Lots more fettling, plug, carb, mag gap etc and it still wont fire up so head off, bore scored really deeply, with scores running the length of the piston stroke, and as I crank it I can see oil passing the rings at bdc.
Dress it as best I can, lap the valves in, reassemble and compression test it, and it has 40psi, but still refuses to fire even with petrol down the plug hole...
Would have thought 40psi of pressure would have let it at least fire up, even if it was crap.
Now, I know I can get a +.030" piston in a engine recon kit for it from the states for a reasonable price, but there is no liner on the cylinder and the piston runs directly in the aluminium crankcase material! whats the life expectancy of a engine like that? Can it be measured in years, or is a more valid unit how long it lasts compared to a packet of wine gums?
Also, does anyone know if there is enough casting thickness to use the cast iron liner from the IC series motors in one, I don't fancy having to spend the first week of each year rebuilding the mower engine when I can improve it a little now and do the job properly...
B*ggering mower, 4 nights work and its still not sorted out.
What it needs is a nice motorbike engine...
